Workshop wall cupboards
Andrew1
13 Nov 2018
Spalding
Hi been working on putting up cupboards in workshop. need a sanity check please
Plan is 32" high x 20"wide x 11 and 5/8" deep
Side panels in 18mm birch ply
Rear panel let into back by 1/3" due to slightly uneven walls, planning to use 1/4" ply for back
Shelves x 2 will be dado inset to approx 1/3" and rabbet for top and bottom again 1/3" deep
stretchers inside cupboard at 18 and 1/2" wide x 3" deep to aid fixing to wall and add some more material for support.
Plan is then to face the cut edge of the ply.
Four questions if i may ask for guidance-
Does the above seem sensible
What thickness of shelves and top and bottom
What would you face the front cut edges with, had though 3/4" x 1/4"
Doors what thickness and what type of hinge, need to be easy to install hinges
With regards the shelves it depends on what you are storing in the cupboards. I so a lot of metal working and most of my kit tend to be heavy. I have found that a substantial hardwood liping makes a huge difference.
Have a look at Sagulator Calculator to get a better idea of what you need.
James
Hi James, thanks for coming back. Just normal glues, paints etc on the shelves. 12mm ply gives 1.2mm at 30lbs, so wont be far away, thanks for the link
