Tasky
sunnybob":1usylimr said:I'm looking for a 90 degree vice....Any ideas?
sunnybob":2iz6gf9m said:I'm looking for a 90 degree vice. something that will hold a largish piece of wood at 90 degrees to if I just put it in the recorcd vice.
sunnybob":1ss9i9tb said:Dont have any sash cramps. all mine are new quick squeeze type.
Depending on your clamps, not the type but exactly what shape they are, you can sometimes clamp something and then clamp the clamp down to the bench surface and have it be quite secure. Alternatively you can clamp a piece of wood across the bench, or diagonally on a corner, and then clamp the workpiece sideways to it.sunnybob":1pe6v5v7 said:Any ideas?
Don't know if this would help but my Record vice is flush with the apron, which is about 12" deep. Hence a workpiece held vertically would bear against the full width of the apron and be pretty stable. Could add a G clamp on the apron if more support needed.sunnybob":3bqcdoqp said:I'm looking for a 90 degree vice. something that will hold a largish piece of wood at 90 degrees to if I just put it in the recorcd vice.
Dogs wont work becuaes the objects are irregular sizes and lengths, but almost always with two parallel sides.
Any ideas?
