If it's being hinged, you will need about 18mm to allow for safe hinge fixing, but if you just need a push up and out jobbie, then 10, or 12mm ply would do, and fit the stops to suit.
HTH Regards Rodders
Mines 18mm ply I think. Does it really matter so long as it looks proper and does it's job. I mean 6mm with a reinforcing frame on the upper side would surely do, maybe even thinner with more frame. My fathers isn't a solid panel, it's a softwood frame with a thin sheet on both sides, does the job just fine. In older houses I've see it made from T&G, probably floorboards - not my taste to be honest but it filled the hole.
Personally I prefer plywood in a frame, this is one I made recently.
I form a rebate on the edge of the 18mm ply which fits in a corresponding rebate in the frame which allows the ply to sit flush with the frame on the inside should a roof ladder be required. The frame gives a good fixing for hinges & helps keep the ply flat.I like to do as much in the shop as I can, I usually make a frame, architrave it, hang the hatch & paint it before installation so minimising time on site
Thanks Phil, to be honest this option was cheaper than the others the customer had looked at, their first choice was a wooden folding ladder but the alteration of the ceiling joists to accommodate one would have been more costly than the one I made that simply fit between the joists.
They also preferred the fact that there would be no decorating doing it the way we did.
