What is this?
The_Yellow_Ardvark
22 May 2020
SW UK
Had this kicking around for a while, but not sure what it is.
In Bits.
If the centre, curved section is rotated 180 degrees when in use, it looks superficially similar to a cant hook used by loggers.
Possibly an oil filter removal tool.
What size (range of) circular object(s) would it surround?
It's a bit of a guess but it looks like it may be for pulling chains, the jaws clamp on a link like pliers, the hook catches a link, then a ratchet can pull the chain up tight by closing the handles tighter as the tension increases.
Total length of the tool is 7".
It's what Tris said: for pulling the ends of roller chains together in order to fit the spring link.
