Although I use a lathe to make drawer pulls I also use a plug cutter and a matched drill to get a perfect fit with minimum fuss. Unfortunately really good matched plug cutters aren't cheap,
That rasp certainly cuts through the fibres, would be easy to mess up a couple at first I reckon.
As Custard said, rather a dusty job
Awkward to devise an extractor for that jobby.
Regards Rodders
that guy is dangerous he cuts the outside of the template first on the bandsaw meaning his fingers are then closer to the blade to cut the inside curve out and hes to lazy to change the blade which means it harder to cut the inside curve of the template and tbh for 2 drawer pulls i would have cut the rosewood wider and cut it as one pull then sanded and split after you then have the identical shape
