Norfolk75":1bgzptli said:
I've already built a 30sqm outbuilding games room with jigsaw which seemed to have took forever, so I'm hoping Not to just quicken my next project up but having the correct tools to just make my job that little bit easier so to speak. Thanks
With a jigsaw! My oh my that sounds like a lesson in perseverance and patience.
I've started woodworking with second hand tools, I have a makita mitre saw for cross cuts (£100 gumtree) and a vintage table saw for rip cuts (ebay £90). They were both a bit beaten up but nothing too hard to remedy if you have some mechanical ability. Biggest jobs were de-rusting of the slides on the mitre saw and bearing change on the table saw arbor, all possible with no specialist tools and a little patience, youtube research, and advice from on here. Often 110v machines are cheaper on gumtree and you can get a transformer, gumtree again, for £30. It takes time as you really have to surf the posts frequently to pick up the real bargains but if you don't have the funds what can you do!
If you do end up looking at ebay for second hand cast iron table saws there are often ones like mine (see image below) that are much cheaper than a startrite etc, c. £50-100. The cast iron table is nice, but the table tilts for angled cuts, and is terrifying so I only make square cuts on it. With a new blade it is a great workhorse, although not accurate enough to go to finish dimensions with, i leave room to use the P/T to get to final thickness. Also beware safety guides are erm, non existent.
Regards
F.
