Hi all, I did a deal with a friend and traded a bit of work for a table saw, it's a SIP with a 10" blade. The insert around the blade was broken so I made one up out of plywood. My first question is whether there should be riving knife directly behind the blade or is the one that the blade guard is fixed to sufficient?
My second question is about blades; the saw came with three blades, two of them have teeth which appear to be brazed onto the disc and the other is a flat disc with heat treated tips. What is the difference between the blades? Do they have different applications?
