Hi there, does anyone know where I can find rafter size guides for steep pitched roofs? The only TRADA ones I can find talk about 30-45 deg max.
I am looking to build a large A-Frame potting / storage shed, based on two 3-4-5 triangles back to back, so the pitch is going to be about 53 degrees. The A-frame span will be circa 5.4m, with the bases bolted to a concrete slab, so the rafter lengths will be about 4.5m, with a ridge height of 3.6m. I intend to support the rafters with a supported purlin at their mid-point. I want the rafters at 600mm centres and the roof will be tiled with plain clay tiles.
If anyone knows what size rafters I can get away with that would be great. Or am I ok just to use the 30-45 degree tables?
