That does not sound right. I have an old Wadkin that has a 5/8" arbour, I use the Trend bushes on a number of different blades, the bush is a snug fit in the blades. I usually fit then by laying the blade on the side of a sledge hammer, offering the bush up to the bore, placing a steel block on the bush and applying a smart tap with a 1lb hammer. There should be no wobble.bookman":195iqj5j said:The blade required a reducing bush which came with the blade, but the bush is actually thinner than the blade and is a rather sloppy fit. I had to fit the blade a couple of times before I got it working with a minimum of wobble.
This may be due to the blade not running true, but some blades have slots cut in then to reduce noise, I recall seeing some with copper slugs fitted part way along the slots to damp the ringing noise from the blade. Does the blade have a max rpm marked on it, are you running it over speed?bookman":195iqj5j said:This blade gets a little noisy with a fairly high-pitched wine/scream, but this is not unbearable.
bookman":2tupda3e said:DaveL seems to be happy with the Draper ones.
Malcolm R said:Sorry Malcolm, you've lost me. Could you explain a bit more? I'm not sure what you mean ...
Apparently the people at SIP fit a device to the riving knife to stop kick back these days. I think they have to do this to comply with some sort of regulation. They have no knowledge of the extra bit of rip fence or the bolts to secure it.
Malcolm R":1beu070y said:This is a picture of the auxiliary fence for the saw. I have not fitted it fully so you can see the bolt that holds it to the main fence and the black knob you see goes on the bolt to tighten the whole thing up.
Hope this helps.
motownmartin":dyk3nd2t said:It probably goes all the way through the fence :? :-k I can't see another way, I am thinking that the bolt is fitting into a slot, dunno.
