RedArcher1968
New member
Hi
I’m new to woodworking and have a SIP 16 inch Bandsaw. I’m looking for a narrower blade to practice some curve cuts. The online instructions has a range from 6mm - 37mm. The instructions included state 10mm - 25mm (However the front cover says SIP 16 inch Pro but the last page ref SIP 14 inch Pro). The sticker on the machine says 9.5mm - 24 or 25mm.
I have contacted SIP’s technical department who I’m guessing read from the online manual 6mm - 37mm?
If you use/own a SIP 16 inch which minimum blade size have you used.
Hope it makes sense
Regards
RedArcher68
Hope it makes sense
Regards
RedArcher68
