Shooting board wear
Mister S
6 May 2011
Southport, Merseyside
A couple of weeks ago I made a 45 degree shooting board, nothing fancy, just using some scrap I had lying around. The base was MDF which seemed ok at first. But after only a couple of weeks of use, it seems the MDF on the "runway" has worn, so the plane sole no longer sits at 90 degrees to the work, it has moved a couple of degrees. The runway on the opposite side, which I haven't used much yet, is still spot on.
I suppose I can tilt the blade to compensate, but this is just a temporary fix. I will need to change the base board.
So my question is, have I been unlucky, or is MDF simply not up yo the job? Should I be thinking of using plywood instead?
Maybe in an attempt to avoid tilting the plane into the work, I have put too much pressure on the opposite side?
Any ideas?
Steve
The quality of the MDF will make a difference but generally, I'd say no, it will last a while but not a long time. Try using some thin plastic for the runways
Aidan
Aidan
A bit of acrylic plastic (Perspex) is also good - Rob
My experience is solely with rather unexceptional far eastern ply and wax; works okay. Might be worth checking the front edges of the sides of your plane aren't sharp and acting a tad blade-like though, 'cos that seems pretty speedy wear to me.
My shooting boards are made from MDF, which I wax occasionally. I've had no problems with them wearing and they've had a lot of use.
Cheers :wink:
Paul
Aidan
+1 for the plastic/nylon :wink:
Thanks for all the advice. I have some perspex sheet as well as the melamine faced board. I might try both, one on my 45 degree board, and one on my 90 degree one.
I really didn't expect my waxed MDF to wear so quickly, so I'm not surprised to hear that others have used it successfully.
Alf, you might have a point. The plane is a LV BU jack. The edges aren't too sharp, but neither are they rounded over. I suppose it's possible the edge could be acting like a scraper with a 90 degree angle. I might try just easing the edge ever so slightly.
Hopefully my next incarnation of boards will be a bit longer lasting!
Steve
