TheDudester
Last year SWMBO decided she wanted our staircase painted white and so it was done.
This year, you can probably see it coming, she would like it returned to a varnished state and so it will need to be.
I have started sanding and what a pain in the a** job it is.
I was able to get a loan of a Festool LS 130 Profile sander which has proved a timesaver especially when sanding the ballisters and some of the rails using the 90 degree profile with a 6mm radius.
Has anyone used one of these before?
The hand rail is coming off so this part should be fairly straight forward.
This then leaves the profile that runs from top to bottom on top of the stringers (?). Would it be easier to just remove this and apply a new one or should I attempt to hand sand it?
Any advice would be welcome.
Regards
TheDudester
Regards
TheDudester
