trees
New member
Hi I need some advice re: Rustins plastic coating
I have parquet flooring which I had varnished a few years ago and now redecorating.
Once I strip the varnish and put the first coat on, do I need to rub down in between coats? if so with wire wool or sand paper?can you put this on top of a varnished floor if it was lightly sanded?
I also have iroko kitchen work tops that were oiled before delivery, how can I remove the oil to apply the coating?
Thanks Trees
Thanks Trees
