okeydokey
Hi good people
I have bought a 2nd hand set of used Sorby Woodturning Chisels/Gouges.
They have been kept well without surface rust on the length of the steels and the handles are as new.
Unfortunately where they have been stored in the makers cardboard box and where they have been resting on the cardboard supporting pieces halfway down the length of the tools there is some rust pitting - more than a surface sprinkling they are quite deep rusty. The rust area on each is say 1/2" x 1/4". Obviously doesn't affect the tool but its a cosmetic thing and rust seems to spread.
Ok with fine wet and dry then buffing them on my small buffing mop on my bench grinder (or my neighbours Dremel with wire brush) I will be able to make the rusty bits mirror shiny but surely they will be the target area or prone for rust to come back.
Question - should I try give a coat of spray lacquer (over to be shiny/ex-rust area) such as Chestnut Acrylic Gloss Lacquer Spray -- other brands are available or try to remember to keep these parts waxed/oiled? Or what is likely to be the best long term fix?
thanks for your hopefully forthcoming advice
