LancsRick
I'll try my best to describe this without resorting to scribbles.
A typical lid has a downwards protrusion inside of the outer wall of the box, to hold it in place. Agreed? Good, hold that thought.
I will be making a lid from an oblong box (metal), by using the box as a guide to run a flush trim cutter against to cut my lid from some hardwood.
I then want to run a cut all away around that lid so I'm left with the downwards protrusion in the middle of the lid so that it sits properly in the metal box. What's my best way of doing this?
The thing that has entered my head is a flush trim bit with a whole selection of removal bearings, such that you fit the bearing that gives you the required overlap of the cutter - e.g. a 5mm bearing on a 10mm cutter would give an edge of 2.5mm. Is that the way to do this though?
Thanks.
Thanks.
