Round over bit burns?
dvddvd
27 Jun 2023
York or surrounding
ive been cutting some various size holes in some timber at 50mm, 40mm, 30mm, and 20mm.
I want to put a small 3mm round over on each of the cut circles.
I used my palm router with a small 3mm roundover bit but no matter how fast I try to do them it still burns the wood. Ive slowed down the router and still the same, any ideas?
Does or would it make any difference if you go clockwise or anti-clockwise around the hole?
Don't be reluctant to try going the "wrong way" around the hole.
Metal machinists call this "climb cutting" and it usually gives a better finish pass than the way we normally move a router, and for a good reason.
You just have to be able to hold the tool back rather than push it around.
A roundover isn't a big cut, it is worth a try.
Try the same on some other types of timber to see if they burn.
If they don't, it's just the type of timber you're using, if they do, check the cutter edges, incase it's been a faulty grind, even new can be poor grind, rare, but can happen.
Hi yes it has a guide bearing. I tried to sand them off with my dremel with a fine sandpaper fitting and that burnt the wood too.
Will try some rougher sandpaper bits on my dremel and hopefully it will sand them off quickly instead of only generating heat the fine grit ones did. If not it will be a hand sand job
Slow the router right down. If it is not variable speed wire in a old light dimmer to make a speed reducer but this is only for small trim routers not multihorsepower giants!!
A little WD40 in the bearing will help. Trim routers can do anywhere between 25 - 35,000 rpm so a slower speed will probably help also. I have found that cherry and maple burn easily - what wood are you using. ?
Clarification please.
Cutter guide causing burn marks?
Maintenance required of bearing.
Cutter itself causing burn marks?
Too blunt or feed rate too slow.
Cheers, Andy
Have you tried taking a smaller cut, You should be easily able to do a 3mm round in 1 pass but have you tried taking off say 2.5mm and then doing a fine finishing cut
Ian
