p111dom
Does anyone know of a source for a Racal Airlite spare battery?
Thanks for that info, Rob. Since NiMH cells seemed to be sold with special charger, I'd assumed they would not work OK with the trickle charger on the Airlite. But in any case, the self-discharge would be a bit of a problem as I only use the Airlite intermittently, but when I do it's always "now".9fingers":pqr5knd7 said:NiMH cells have a higher energy density and use a similar charging regime.
The only reason to stick with nicads might be if you have a fast charger ( 1hour or two) where the specific properties of the NiCd chemistry is part of the rapid charging process.
p111dom":8dqmprcs said:Cant find Nicd in that spec. Would these do the trick?
http://www.eurobatteries.com/sitepages/description1.asp?id=1867&cat=NIMH
