Oh Name That Machine, Where Art Thou?
Scrit":1os35pd1 said:
goes by the catchy name of "Haunching and Relishing Machine" and was specifically made for the sash trade......
Might I helpfully suggest that other UK Workshoppers don't type "haunching and relishing" into a Google Groups search. :shock:
Phil the book is Ships Joinery by S G Duckworth 1923 .
As for the haunching and relish thing , maybe the relish is the scroll on the bottom of the top sash ? I seem to remember my collage teacher saying "putting on the relesh " I E the fancy bits .
Scrit":38cpe7mz said:
The question is, what is a relish?
Well, I did a bit of searching and found the following
Relish \Rel"ish\, n. (Carp.)
The projection or shoulder at the side of, or around, a
tenon, on a tenoned piece. --Knight.
So now we all know it's nothing to do with anything hot and spicy!
MisterFish
Scrit":2uk0tzjz said:
The giant pencil sharpener is indeed a pit prop pointer:
Scrit
I'm a bit curious about this one. I used to work in the pit and I've never seen a pointed pit prop, and can't think what they would be used for. The whole point (or not :roll: ) of a pit prop is to support a load, so you want the ends to be as flat as possible. I was wandering if it was for putting points on fencing stakes?
It looked straight":2l020nem said:
Scrit
Assuming scrit didn't put the text on the picture himself, I'm guessing it really is as the manufacturer describes it.
Scrit
I'm a bit curious about this one. I used to work in the pit and I've never seen a pointed pit prop, and can't think what they would be used for. The whole point (or not ) of a pit prop is to support a load, so you want the ends to be as flat as possible. I was wandering if it was for putting points on fencing stakes?
I also worked in deep mines and small mines (18th century way of winning coal) :x where you notched the timber for road supports and cannot fathom out why you want to put a point on a post.
Unless it was to take a crush, but then you would put pads under the post.
Maybe the "pit" is a bit misleading and the pits being referred to are just holes in the ground, rather than mines, so a "pit prop" shores up a hole in the ground, rather than a mine. Then you'd want them pointed so you could bash them into the ground at the bottom of the hole.
/wild speculation
