Hi all,
My new shed arrived today and want to make sure I get things right from the start. I've read other posts about insulation and watched numerous YouTube videos and there seems to be a lot of conflicting advice.
I've got some Barratine Log Cabin treatment for the outside but should I treat the inside too?
I've got breathable membrane to cover the inside and roof. The framework is 75mm deep which I intend to fill with Rockwool as I want to soundproof as much as possible. I read lots about leaving an air gap but the framework is enclosed so is this needed? I'll be using OSB or ply to cover the Rockwool. I will be leaving a 25mm air gap in the roof.
The floor will be covered in DPM, then membrane and 18mm OSB on top. Does it also need some form of insulation and if so, what is the best to use? It's not on a concrete base so limited cold coming directly through.
Any advice appreciated.
