My tip for improving tablesaw accuracy
A
Anonymous
Guest
Hi all
Just though I'd post a couple of ideas i had to improve my kit. First is to allow more accurate positioning of the tablesaw fence on my Kity (used same trick on old record).
I got a bar magnifier from Tescos for about £5.00 and has 3x magnification + a thin blue line along it. I made a small aluminium bracket with slotted holes to allow adjusment. I cut the magnifier down to size and sanded an angle on it to macth that on the fence support using my disc sander. I also sanded the top end at the same angle to sit parallel to the table top. I drilled, tapped and screwed the magnifier to the bracket and there you have it. Magnified scale - seriously accurate and repeatable cuts are now possible.
cheers
Tony
Alf
22 Oct 2003
Up the proverbial creek
Tony,
Brilliant. I've had one of those magnifier things, minus little blue line, kicking about for years. I was so enthused I just this minute dashed down to the workshop, lopped off the end of it and with a little tweaking with a scraper got it to a nice wedge fit into the hole in my bandsaw fence. A little craftwork (tm Woodrat) and I had a cursor to line up with the scale. Voila, a magnified scale for the rip fence. Muchos gracias. :D I should send it off to one of the mags if I was you.
Cheers, Alf
Possibly now the holder of the world "from page to workshop" speed record. :D Of all the unlikely holders... :roll:
A
Anonymous
Guest
Alf
Scraper :lol: :lol: :lol: :lol:
Aragorn
If only the carpet was in the workshop. That picture was (I'm sure you guessed) taken in the study, not the workshop :cry: :cry:
Glad the idea helped - I have a few more little tricks I have tried out (copy of Biesemeyer fence for my record tablesaw for instance) and must get around to photographing and posting 'em
Tony
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi Tony
I think you're on a roll, don't stop now.
Neil
Noel
Moderator
Staff member
Moderator
7 Aug 2003
Yes, by public demand post a picture(s) of the Bies type fence. I've seen wooden versions, so will be interesting.
Rgds
Noel
devonwoody
11 Apr 2004
Paignton Devon
Hi Tony
Do mind if I mention that your messages exceed my screen allowance in this forum. Other members messages appear within the frame OK.
Is it me or you?
sawdustalley
7 Sep 2002
Guildford,Surrey,UK
I think its the face ha is using large photos, you probably have 800x600 resolution, and the photos are too wide to fit on your screen at this res. 8)
A
Anonymous
Guest
Oops.
Sorry about the size. I will use 640 *480 or smaller in future (Biesemeyer Fence post under construction :D )
