jhwbigley
Well I finally got my phase converter on Wednesday, plonked it on the floor in the corner..
I then set about wiring up my machines. After the lass behind the counter at my local electrical wholesalers couldn't give me what i needed , I ended up picking up some bits on the way to skeggy.
after an hour i was ready to try some machines.. spindle moulder fired up fine, so did the power feeder.
2 speeds forward and reverse baby!
Then tried the planer, well that fired up once.
But after that the starter just "chattered", tried cleaning the contacts, but still buggered, new coil then
And finally it tried the SAW
Well, at first it tried to go backwards... then wired the right way, would cut the converter off, and only turn the blade about 4".
After looking at as much as i could I'm thinking the brakes not coming of?
There is also this switch on the side that looks like it turns the brake of on start up?
And the yellow and white bits are lights, well if they had bulbs it that work!
Now it wont do ANYTHING!.
Any ideas chaps??
JH
Any ideas chaps??
JH
