Multi point locks
HOJ
21 Oct 2014
South Norfolk
Can anyone recommend a multi point lock product, I will be making 3 sets of Oak french doors, 56mm thick, looking for a system that will work on a door that is in the region of 2260mm tall, it only needs to be fitted on the master leaf, as I will fit shoot bolts on the slave doors.
I found one at Ironmongery Direct, the Ferco 3 Point - uPVC/Timber - Multipoint Door Lock - Kit 2, which will work up to 2285mm, but not sure of the quality.
Westward do have some good systems for sale.
Make sure whatever you end up getting is stainless steel, regular steel will blacken the oak.
Thanks for the info, will check them both out.
Meant to say needs to be Stainless.
