Grandad Les
My cheapo B & Q mitre saw is 15 years old and has been used occasionally for right angle cuts only. I need to make a number of 170 x 125 x 50 mm display frames from 10 mm pine. Any tips on improving the accuracy of my saw or should I splash the cash on a new saw?
Also is it better to cut the miters with the 50 mm sides upright (blade at 45 degrees to the fence) or with the sides flat on the table (bevel cut, blade at 45 degrees to the table)?
