MDF- HELP
Jezmaster
19 Oct 2006
London
hi, is it possilable to stain or oil, like danish oil, on to mdf, as i do not want to paint it?
Yes , but I recconmend a sanding down with a fine paper - 240 or 280 grade, just to "break open" the surface.As sometimes after the manufacturer has pressed the surface, it takes stains unevenly.
Danish oil is no problem as I have used it to " water proof " sheets in the past.
ok cheers ill try some clear floor stain varnish, as it can go o with a sponge
