Making sash windows - rail and stile dimensions
rich1911
2 Feb 2019
dorchester
I'm working out the profile of sash stiles and rails when using double glazing and wanted to do a quick sanity check.
Looking at U-value requirements (unless the planning dept say otherwise), I will need a 22mm thick unit. Centre of plane U value 1.2 which is a 4-14-4 with argon and softcoat.
Allowing 2mm either side for window tape.
Aiming for a stile/rail width of 45mm to keep the overal proportions similar to the original. Is that possible? It only leaves 9.5mm either side for beading.
For the rebate, if I want to have a 3mm? air gap all round and make sure the edge seals are hidden, the rebate needs to be about 15mm deep? So the glazing bead would 15x9.5mm.
My existing widows have a 9mm parting bead and 22mm staff bead and outer lining. Total depth of the frame is 143mm. The reveal is 43mm.
So should I try and keep the sash rails/stiles at 45mm or widen the frame, growing it inwards say 20mm and going to 55mm rails and stiles to allow a glazing bead of 15x14.5mm. Modern wood sashes apear to be 57mm and the frame is 160mm deep.
For seals and clearance, should I allow 2mm + 2mm between the stiles and parting/staff beads?
Please rip this to shreds if I am barking up the wrong tree!
    61 KB
Are you making a complete new window or repairing an old one with new sashes? If the latter, use 4-6-4 glass with low-e and Argon (most cost effective) and use a 32mm rebate, 14mm bead. U values dont matter if your repairing. Even if your replacing, new windows should, by the letter of the book, have whole window u value calculations not just glass u values and also CE marking, although im sure your Inspector wouldn't know this...
I absolutely hate glazing tape, horrible product and I don't know why people bother with it. You get a much better and neater seal with low modulus neutral cure silicone. Tape grows to look filthy in a couple of years.
Ideally, you want your beads to be as close to square as possible, I would say 9.5mm isn't quite enough to hold the glass firmly.
My 24mm double glazed sash boxes tend to be 158mm thick, which allows for 2 X 55mm sashes, 6mm wooden parting bead, 1mm per sash clearance between the sash and parting bead/staff bead and 20mm inner and outer casings.
I will be starting a boxed sash job in the very near future and I did promise to do a thread on sash making while I was doing it.
Yes please, a box sash WIP would be awesome. Have 10 to renovate or replace at some-point and all the questions above have been circulating my brain for a few years.
F.
Hi Bradshaw Joinery,
Difficult to say if I am repairing. As the cills and outer linings are rotten, I had intended to replace.
I don't want any scarf joints. So only the head and inner lining will be salvageable. All the sashes will be replaced.
I'd like to use thin units but I keep reading horror stories about them. I don't understand why a thinner unit would be more likley to fail?
Yes, I ready that 1.6 is the whole window which is pretty difficult to measure I would think! Centre of pane at 1.2 seems to be a rule of thumb...
Thanks for the input Trevanion.
So many ways a means to glaze a window! Theres the whole wet/dry thing too....
I guess the important thing is to make sure that whatever you use is compatible with the DGU seals. I have no idea if butyl tape is better than epdm seal or if silicone mastic is better than those.
I, for one, would be interested to see your thread of a sash build. The more pics the better!
Cheers!
If you are re-using any part of the originals then you are repairing, I think... can’t imagine that BC give that much of a toss TBH.
Also, I think this means you should be able to have single glazed units rather than be forced into double glazing.
