Lidl vac back in store
martinka
19 Jan 2013
Wakefield(ish), West Yorks
I've had mine 3 or 4 years and it's been flawless, though unfortunately not as quiet as the Henry. It's 1500w, has a socket so you can plug the scroll saw into it so that vac comes on at the same time. Can also be used as a blower, though I'm not sure what use that is; why would you want to blow sawdust around your workshop? ;) Can also vac up liquids if you live near a river/stream/beck that floods occasionally.
B&Q has a Mac Wet & Dry that looks similar on clearance £48.
Check that local stores have it first - min had 3 available.
Brian
