You just as well burn what you can get hold of.
As around here you don’t have a choice of breathing fumes in the winter, the air is heavy with the fumes from so called clean wood burners, I don’t have one, I use mains gas, now somebody will comment on how burning gas is bad for the environment. It probably is, but we have gone past the point of no return for the environment, and it is not at the hand of man.
Man is not capable of generating enough pollution or otherwise to damage or save the environment, or to control climate change, much greater forces are responsible.
Take care.
Chris R.
