If I had a pound for every shaving....
Woodmonkey
23 Nov 2013
Bristol
All from one bowl....
What do you do with it all?!
    224.8 KB
Mine goes on one of the composts and is eventually incorporated with other composts and then the into the soil.
I bag mine up and give to my father in law for his animals bedding.
It's amazing a small chunk of wood can create such a huge pile of shavings.
At times I produce a fair mountain of the stuff. It can get on top of you.
Then I found this video and now I incinerate my dust and shavings in an oil drum. :)
I don't use the burner as a stove, I don't really have the facility, but using a length of 6" soil pipe to form the chimney I can burn a 45 gallon drum of shavings in 5 or 6 hours.
Genius.
https://www.youtube.com/watch?v=jMdRRhVJorY
Do be careful with some timbers- walnut and yew for instance are poisonous.
Laburnum also is not animal friendly I killed my grandkids rabbits 2 years ago but never took the blame directly
Bill
Compost, take a year or two to rot down but in the end it makes very good soil improver.
or hickory, apple, cherry and pear.
I wonder if there's a market? A decent sized polythene bag at a quid a go, or something like that. It goes on barbecues as well, and most people haven't got access to it - specialist suppliers charge a small fortune for the stuff. A few beer tokens here and there for something that would have been throw away can't be bad.
It grieves me to see good wood as shavings, it is the main reason I am contemplating getting a woodcut bowl saver.
I do have uses for them though, as animal bedding and it helps my heavy pottery quality clay soil immensely.
I was going to say - if your lathe is powerful enough (minimum probably 1hp) consider getting a bowl saver - it's faster and you don't waste most of the wood as shavings
Guinea pigs and compost for me with the occasional burn. But I find they don't really contribute that much to an open fire. They tend to produce a lot of smoke and have a dousing effect. They also get everywhere and don't really burn that hot. Not in the same class as solid wood. I know some folks pack them tightly into cardboard tubing like loo roll or kitchen roll holders which holds them together better. I've also seen those log producing machines at shows where they compress the shavings together to make very compact wood burning logs, but they cost a small fortune.
My compost heap is overflowing with them.
