mailee
I would like to pick the brains of all the pros on here if I may? I have been asked to quote for a set of built in robes that slide out. I know it's a bit unusual but it is due to the space in an alcove. The alcove is 1000mm D x 1140mm W x 2360mm H. My idea is to make two robes of approx 500mm wide and 1680mm high with separate top boxes. Both of the robes will need the interiors to slide out with the clothes rail running front to back to gain the maximum storage. I have looked at the slide out larder gear but this comes complete with baskets ETC and is pretty expensive to be throwing half of it away!
So I have been thinking I may be able to use two sets of heavy duty runners on each robe for the slide out mechanism. My intention is to build a base runner at the bottom and another at the top of the robe 'box' and then attach a hardwood frame to these to hold the rail and the door. The runners would need to be the longest available which look like they are the 700mm versions which are full extension. I realise they would be smaller than the depth of the robe but the customer realises and accepts this. I have added some drawings to hopefully make it a bit clearer from my ramblings. I would like to ask if you think this system will work? Here are the drawings of what I intend.
