ByronBlack
Dave R":nsskyrba said:Here's another option for you. If you leave the arc, carry it on to the stiles. Make it an elliptical curve so it can be tighter at the ends.
There are a couple of ways to do what you want. If you delete the radiused edge, you can draw in lines to extend out to the corner and a line along the length to create the faces. Depending upon what you have going on in the neighbourhood of the radius, you could just draw a vertical line to the side of the radius and use Push/Pull to cut the radius off. then use Push/Pull to pull the new edge out to where the old one was. If those don't make sense, I'll make you some pictures.
I went ahead and made a quick illustration. Click on it for a bigger one.
Dave - Thanks for that, that makes perfect sense, and will save me a lot of time in the future.
Jason - I agree that the frames are now a bit too thick - they are like this because I was feeling too lazy to adjust the door components, but I will be re-working this to have thinner frames. I then get to present this to the 'client' on sunday, hopefully she'll like it and give me the go ahead.
