@inkyblue:
I agree with all the above - if it really is cast ali (or even worse, pressure die cast "monkey metal" - looks a bit like cast ali but has a high zinc content and can be overall a bit of a duller grey than ali) then in my experience you're on a hiding to nothing trying to straighten it out.
The idea of replacing that plate altogether (with a piece of sheet steel) is a good one, but depending on how complex that base plate is (holes, slots, etc, etc) it could be quite a bit of work making a new one (but by no means impossible).
IF there is a small piece of the base plate that you can safely cut off with a hacksaw without damaging it any more than it is already, it's worth while having a look at the cut off piece - if you break it in 2 has the break line got a dull grey granular structure? And how difficult was it to break, easy, or pretty tough?
An approach to trying the repair is to take a broken piece from the off cut and apply a normal plumbers blow lamp to it, but be warned, most aluminiums melt at around 700 deg C (cast monkey metal a lot less) and the hottest part of the flame on a standard propane plumbers torch is at least 1000 deg C, so go easy. A trick here is to see the temperature change happening on the metal by coating the part with a bit of damp toilet soap - when the soap coating turns a dull brown then stop heating! Is the piece now a molten blob or is it still intact? If intact you can try a repair by heating the complete bent plate in the same way, again coating it in soap so that when the soap turns brown you stop heating and try bending it straight - GENTLY!
The chances are it will snap at the point, leaving you with 2 choices (apart from making a new one from steel).
Choice 1: - Google for aluminium welding/soldering rods (there are several on the market), get some scrap ali for practising on, follow the instructions (and there's at least one video on Youtube showing it being done) and when you're comfortable with the procedure, try welding the 2 bits of plate back together. It CAN produce quite acceptable and strong results sometimes (but NOT always)! And you need to work out in advance some sort of (heatproof) "jig" to hold it still during the repair.
Choice 2: - If your broken sample piece melted in the test above, or if you're not happy with the above aluminium soldering/welding idea, then just try bending the plate back straight without any heating. It may or may not straighten without heat - probably not, so if not, it'll again leave you with 2 pieces to join. There are various cold metal epoxy "welding" glues on the market but I've never tried any although I've heard good reports. My own fall back in that situation is to use the old original Araldite (needs at least 24 hours to harden, NOT the newer 5 minute stuff). Make sure the joints are VERY clean (acetone is good), work out some "jig" arrangement with ply or something to hold the parts together for the 24 hour+ hardening time, mix the adhesive EXACTLY as per the instructions, apply to both parts, and cross yer fingers. You can decrease the hardening time by heating overall, gently in the oven (IF domestic authorities allow - but make sure you take steps to catch any overspill in the oven - NO, don't ask!). 80 degrees C needs about 3 to 4 hours in the oven, depending on size/mass of the part. Araldite does produce some very good results provided the joint is VERY clean before applying adhesive, provided the mix is exactly as per the instructions, and provided the parts are held perfectly still and straight throughout the hardening period.
The only other thing I can think of is to find a professional ali welder with a TIG set up (because trying to straighten it will almost certainly break it, or if not then at least badly weaken it - ali does something horrible called work hardening when you bend it, making it tend towards being brittle). But TIG is likely to be costly, so only really worthwhile if it's a valuable/expensive tool.
Sorry if any of the above is teaching granny, good luck, hope it helps
AES
