I am looking for a grinding jig for plane irons and chisels (not woodturning). I have had an O'Donnell for ages but am finding it clumsy and tedious to attach and set up. I have looked at the Veritas Grinding Jig (please see the attachment) which seems good (but I haven't been able to see the real thing).
The only negative feature I have thought of is the way in which it attaches and detaches - by two bolts facing downwards with wingnuts underneath the board on which the grinding wheel is mounted. My setup includes a pull-out rod under that board which has a socket for holding a spindle gouge sharpening jig - the usual woodturning setup. It would therefore be complicated to allow access to the wingnuts. Perhaps I could permanently fit the two bolts pointing up on the grinding setup and fit the wingnuts on top of the jig's baseplate. Or fix the jig permanently on a wood plate and use downward pointing wood screws to hold that wood plate, and remove it when needed for woodturning sharpening.
Is there some other jig available? What do people here recommend please?
