Galooting ain't easy :(
houtslager
16 Nov 2002
South of France / Chipping Norton
http://www.thewoodbutcher.eu/page4.html
Well I am going to try and make this cabinet without any power tools.
Which means lots of hand sawing planing then I would normally do. :oops:
But it means I can use the living room to work in, thereby staying nice and warm.
Another advantadge will be as I cut the off cuts, I can throw them straight into the wood burning stove :D, thus keeping me warm even more so.
On the same page is a SU drawing of the cabinet I intend to make, for those interested I have estimated the time to make this cabinet as 45 hours.
The finish is a Limed oak using OSMO floor lacquer.
That's all for now - need to lie down after all the prep work :? :oops:
houtslager.
I have just looked at your link, and there is a lot of text over text. Why is this?
Usually when I come across a site with text over text I leave immediately.
1. It dose my eyes in.
2. Why should I use my time getting a headache when the site owner doesn't care about there site.
Please don't take this the wrong way. It is not a dig. I know that I am not very good at explaining things and they sometimes come out wrong.
The link worked just fine for me. Not sure about the workbench in the living room though :shock:
I also have IE6.
This is what I see:-
:shock:
Neil, George_N, if you see everything as it should be, then I ow houtslager an apology. [-o< I didn't realise the we got different views. :oops:
Hmmmm Gary I don't know what's happening there I've checked it with
IE 6 and 7 and Firefox.
Neil - very simple its my house and I live on my own - well till the G/f visits - so stuff in the bedroom is a no no but everywhere is ok :D
garywayne":1o6lniw5 said:
I also have IE6.
:shock:
Gary, hold down the <Ctrl> key and wind your mouse wheel (gently) away from you - that should cure the problem.
If you don't have a wheel mouse, hold down <Ctrl> and hit the minus or small dash key until OK (the + or = key puts it back to where it was).
Ray.
houtslager,
Looks like a nice project, what plane are you using to scrub the wood down? I'm planning on Galooting some Iroko soon and had in mind a #4 set very coarse.
SeanG
garywayne,
The text-over-text thing you're seeing is because you're using larger fonts. If you turn the text size down then it doesn't overlap anymore.
Fecn
Argee, Fecn.
Thanks, works a treat.
houtslager, again I apologise. :wink: Just goes to show that I'm a bigger . than I originally thought. :lol:
Nice site.
SeanG asked
:oops: sorry mate I cheated here and ordered the timber PAR slightly over sized, so I did NOT have to make mountains of shavings.
I ased a number 51/2 with SS then where I expect to have roque grain my scraper plane.
hope this helps
HS nursing a broken tooth and not wanting to visit the dentist :?
