Friday 20th - don't be in the dark!
KevM
17 Nov 2013
Dorset
A partial solar eclipse
On Friday 20 March a total solar eclipse will occur across the Arctic and in the far Northern regions of Europe. This is the last total solar eclipse in Europe for over a decade, with the next one not due until 2026
The UK will experience this as a deep partial eclipse with 84% of the Sun covered in London and 94% covered in Glasgow, Aberdeen and Edinburgh. In north-western Scotland, the Hebrides, Orkneys and Shetland Islands the maximum obscuration will exceed 95%.
In London the partial eclipse will start at 8.45 with the maximum eclipse at 9.31, before ending at 10.41 when the moon will pass completely from in front of the sun, thus ending the partial eclipse. In Scotland the partial eclipse will begin 15 minutes earlier at 8.30 in Edinburgh, and in Northern Ireland and Wales it will start even earlier, starting at 8.26 in Belfast and 8.23 in Cardiff.
If you're planning to watch it make sure you get some proper solar viewers to avoid eye damage.
For those who do want to see it here is a site that at leat tells us where/when it be!!
http://staging.timeanddate.com/eclipse/ ... arcassonne
On one of the eclipses I wondered what in the house I had that I could take photos through and I found that the black part of an x-ray film was ideal and the photos came out well. They may well be on our iMac and I am on our MacBook??
I have a fair number of x-ray negs to choose from unfortunately :shock: :shock: :shock:
I was thinking of a welding mask. NASA's website suggests using welding glass rated as number 14? It also warns against unscreened viewing of any partial eclipses- only total eclipses are safe for unshielded viewing. Also X-ray films are not safe for viewing,( but OK for cameras I suppose?)
Here's the full text of their advice, for those who are interested, or those who want to read it because they are just too bored to do anything else.
K
The Sun can be viewed safely with the naked eye only during the few brief seconds or minutes of a total solar eclipse. Partial eclipses, annular eclipses, and the partial phases of total eclipses are never safe to watch without taking special precautions. Even when 99% of the Sun's surface is obscured during the partial phases of a total eclipse, the remaining photospheric crescent is intensely bright and cannot be viewed safely without eye protection [Chou, 1981; Marsh, 1982]. Do not attempt to observe the partial or annular phases of any eclipse with the naked eye. Failure to use appropriate filtration may result in permanent eye damage or blindness!
Generally, the same equipment, techniques and precautions used to observe the Sun outside of eclipse are required for annular eclipses and the partial phases of total eclipses [Reynolds & Sweetsir, 1995; Pasachoff & Covington, 1993; Pasachoff & Menzel, 1992; Sherrod, 1981]. The safest and most inexpensive of these methods is by projection, in which a pinhole or small opening is used to cast the image of the Sun on a screen placed a half-meter or more beyond the opening. Projected images of the Sun may even be seen on the ground in the small openings created by interlacing fingers, or in the dappled sunlight beneath a leafy tree. Binoculars can also be used to project a magnified image of the Sun on a white card, but you must avoid the temptation of using these instruments for direct viewing.
The Sun can be viewed directly only when using filters specifically designed for this purpose. Such filters usually have a thin layer of aluminum, chromium or silver deposited on their surfaces that attenuates ultraviolet, visible, and infrared energy. One of the most widely available filters for safe solar viewing is a number 14 welder's glass, available through welding supply outlets. More recently, aluminized mylar has become a popular, inexpensive alternative. Mylar can easily be cut with scissors and adapted to any kind of box or viewing device. A number of sources for solar filters are listed below. No filter is safe to use with any optical device (i.e. - telescope, binoculars, etc.) unless it has been specifically designed for that purpose. Experienced amateur and professional astronomers may also use one or two layers of completely exposed and fully developed black-and-white film, provided the film contains a silver emulsion. Since all developed color films lack silver, they are always unsafe for use in solar viewing.
Unsafe filters include color film, some non-silver black and white film, medical x-ray films with images on them, smoked glass, photographic neutral density filters and polarizing filters. Solar filters designed to thread into eyepieces which are often sold with inexpensive telescopes are also dangerous. They should not be used for viewing the Sun at any time since they often crack from overheating. Do not experiment with other filters unless you are certain that they are safe. Damage to the eyes comes predominantly from invisible infrared wavelengths. The fact that the Sun appears dark in a filter or that you feel no discomfort does not guarantee that your eyes are safe. Avoid all unnecessary risks. Your local planetarium or amateur astronomy club is a good source for additional information.
In spite of these precautions, the total phase of an eclipse can and should be viewed without any filters whatsoever. The naked eye view of totality is completely safe and is overwhelmingly awe-inspiring!
Yes all good above.
Binoculars work really well. Stand with your back to the sun and hold a piece of white card in one hand and the bins in the other, big end towards the sun. Jiggle the two about until you have an image of the sun on the card. You get a really clear image and there is no risk of eye damage. Brill.
S
Filmed/video the last eclipse in 98? From the Velux in roof wanted to get shot of the big shadow coming over the local area . Left the camera running and went down to watch from garden.
Reviewing my masterpiece I was impressed how dark it was - lens cap was on...
Here's NASA's map
    181.1 KB
Has it started? Where's Dara O Briain?
Spectacular view from the garden and almost 09.38 - 95% apparently:
Getting a bit dark but no more than usual on a wet day.
It was beautifully sunny hear at 9am. I got my bins out and projected it on to the wall. I was just starting, but I couldn't keep the bons still enough and they don't fit on my tripod.
But then I thought about my camera and took it outside. But even stopped right down I was letting in too much light:
And then disaster struck, it started to cloud over :(
But then a little hole appeared in just the right place
I'm happy.
    161.7 KB
    143.7 KB
    133.7 KB
    134.8 KB
    138.9 KB
