frame/box jig (already shown in projects)
stef
16 Jan 2007
Normandy
really pleased with myself on this one, although it's probably nothing special !
I meant to build one for ages, but finally came across some suitable "plastic" (a bit like the plastic from butcher's blocks)
around 10 euros of parts.
Very nice Stef
I've seen something like that for gluing picture frames but this will "cover" much more - boxes drawers and alike....and with almost 90cm (or if you like 900mm :) )....and, you can interconnect 2 threaded rods for longer lengths (but you shall have to use M10 because the M6 will bent, I suspect).
The only improvement that I would make is, to change all the wing nuts with Knobs for faster turning and more power.
Regards
niki
cheers.
the threads are m10, 1meter long, so problems with size ! i could probably work out some extensions system if required.
I made one of these some years ago, I still have it, it takes forever to screw up to adjust, I did see in a book once of some nuts that slide down the threads and do not bite until they come under pressure, I'd, like to get some of those.
Derek.
Derek.
Yes, i also found this. the first 2 nuts drove me, well, nuts.
however.. a dab of wd 40 on the thread, and then using gravity...a flick on the nut makes it travel a good 10cm !
much easier and useable !
You could make some from standard nuts. Mount the nuts on a drill press at an angle (in a fixed vice) and drill through so the threads are taken out on one side at the top and the opposite side at the bottom.
Derek try screw fix for slip on lock nuts they may be what your looking for . Frank
