So I routed out the larger sized holes needed for my subwoofer with a jig, without any issues. But I also needed to do a smaller sized hole to fit in the speaker cable connectors. I decided to do this by hand but what resulted was far from a circles and too big
I've attached a couple of pics to help show what I've done.
What I would like to do is to some how resize/mould the hole so the terminal fits well. The current oversized hole only allows two screws to be used and if the fix can allow the use of more then that would be great - but the primary result is to get a good tight fit.
I have to hand pva glue and pollyfilla and also some mdf off cuts - but I think a plug may be out of the question due to the odd size and fit required.
