TheTiddles
I'm soon to start on a fitted unit for our spare beroom, it's going to run the entire length of the room (9') be about 14" deep and floor to ceiling, the ceiling being the 40 degrees or so slope of the garage roof starting about 2' up the wall, not that the dimensions are critical to the question which is...
Given that I'm using faceframe constuction, what's the best way to construct the back units?
Option 1 - is the cheapest, sheet uprights bolted to wall, floor and ceiling so the shelves are sitting between them, so the wall is visible through the back and the chipboard floor is underneath the bottom shelf, sounds ugly.
Option 2 - Make each cupboard like a kitchen unit with a structural base and sides, a thin back then join them together and to the wall before fitting the frame on the front.
The bottom edge will have a skirting board on it and the new carpet will fit up to that, the face frame will be beech probaly 2" wide and 1" thick is enough?
Presumably these are the only two options unless there are any other ideas?
Aidan
Aidan
