trumpetmonkey
Up until now I kept struggling to get a good finish on pine that is to be stained, after sanding. After thorough sanding the pine can seem silky smooth, and clear varnish would fine, but staining reveals swirls and scratch marks.
I have finally got a random orbit (just a cheap £30 titan one from screwfix) and using this from 80 grit through 120 to 180 grit, then hand sanding along the grain with 180 grit has given an acceptable finish. Used rustic pine colored briwax (was going to use a separate stain then Finpol but had to save time)
The problem has been orbital sanders I used up to now- why do I keep getting swirl-scratch lines? What is the benefit of ever using an orbital as opposed to a random orbit which seems to avoid this issue? What is the recommended sanding procedure to take planed edge-glued pine planks up to a good finish? And any advice on recommended models of sander (belt/orbital or random orbit)
