Filling large holes in MDF
RogerS
20 Feb 2004
In the eternally wet North
Owing to an oversight (I blame the instructions), I've routed out the holes for my cabinet door in the wrong place. I've tried using two-part Unibond Repair Wood for Good to fill them prior to rerouting but the resulting plug doesn't adhere to the MDF very well. Is there any better stuff or is there something to put on the MDF first?
Roger
IIRC It's Epoxy if you want to rout over it again ?
I have had success repairing MDF doors that have had hinges or fasteners ripped out by glueing in an MDF Plug (turned to size or shaped to fit) with ordinary PVA.
You could always try turning an MDF plug (if you have a lathe, of course) that's slightly tapered around the edges, so that after you tap it in there won't be an obvious glue line (plus, you don't have to worry about turning an exact fit!) :wink:
As already suggested cut an MDF plug and glue it in.
Two-part wood filler is usually quite good. Are you leaving it long enough before trying to re-route the hole? I would have said at least 30 minutes to set properly, before trying to re-route. I use the "Metolux Timbafil Premium Soft Stain 2 Part Wood Filler" A link to this can be found below and is the fourth item down the page. http://www.everbuild.co.uk/products/35,Fillers-and-Decorating-Sundries/37,Wood-Fillers/1
Hope this helps
