Hi
I have a problem with the sanding sheets (80 grit) in that the backing comes adrift, ie it remains on the soleplate base but detaches from the sanding sheet. This has happened on three sheets so far (the first ones that I have used), the surface of the sheet is not worn and is OK, but of course cannot be used due to it not being able to adhere to the soleplate. It has made a bit of mess on the soleplate. I have managed to peel some of the residue off. This is a new multimaster and the sanding sheets came with it so must be sourced by multimaster. I was using it for a period of approx 2 hrs each day over a 2 day period at its highest speed, sanding down a cedarwood greenhouse. I have not tried any of the other grits it came with. Has anyone else had this problem or can advise if I am not doing something right?
Con
Con
