Been making this table in Sketchup, it's 230cm x 90 cm wide and 74cm high:
Cross leg design which I like the look of, half-lap joints + glue for the legs. Sliding dovetail battens + breadboards keep the table flat, the legs have cutouts and I have planned that they will either just rest on it, or maybe use a removeable dowel or something, so the table and legs can be separated for winter storage and transport.
Now instead of a beam that goes across, I copied a design I found from a woodworking firm in northern sweden with two support beams instead. I have not yet drawn a joint for how to connect it to the underside of the table but I am considering a shallow mortise and tenon.
I like the look of this design but I wonder if the table might have a tendency to sag in the middle like this. What do you think? Perhaps some gluing a pair of boards lengthwise under the table top, between the two battens, would help? Could use some kind of half lap or mortise though the battens to attach the boards on both sides too. If it's neccessary that is. Never designed or built a table before.
