NickUrquhart
I'm restoring 4 Oak Edwardian dining chairs which have pad seats that are sadly no longer of this world. The originals were standard dowelled Beech and Oak scrap for the frames, with a bit of 1/8" ply tacked on top. I've just ran out of 3.7mm ply, but have a sheet of 9mm.
My question is, being a tight wad, can you hand plane one face to get the thickness you need, without exposing a softer/unstable inner core. Stupid question probably, but i was wondering if they just use pretty stuff on the outside and then a material which won't hold up on the inside if it is exposed. Normally i'd go ahead with the no.5 and make expensive shavings, but thought chances are someone will have done it before. Thanks in advance for any suggestions.
all the best, Nick.
all the best, Nick.
