ScottGoddard
Hi, as anyone put an extractor in the rafters?
ScottGoddard":1v9pdog8 said:Dust via the top bag remaining up there building up where i cant get to (very easily)...
shed9":26l7fq5w said:You could fit a cyclone and remove the top bag from the equation all together.
Myfordman":3b35twd6 said:ScottGoddard":3b35twd6 said:Dust via the top bag remaining up there building up where i cant get to (very easily)...
Ah! ok understood. My blower is hung in between the rafters but the dust collects in a bin on the floor for ease of emptying.
the exhaust filter is also hung off the rafters and only gets cleaned out every couple of years when the mood takes me.
The arrangement means the floor space consumed is minimal ~400mm diameter.
I did post a video many moons ago and will search for a link to it.
Here it is post171559.html
Somewhat horrified to see it is over 10 years ago that's about 130 moons! but still going strong.
That must mean over 11 years since Barry died RIP
EDIT: My video seems to have been deleted by photobucket. but the stills give an idea of the arrangement.
I might still have the original but will take some searching for!
shed9":gh93nj5b said:You could fit a cyclone and remove the top bag from the equation all together.
ScottGoddard":13r5c9wq said:Myfordman":13r5c9wq said:ScottGoddard":13r5c9wq said:Dust via the top bag remaining up there building up where i cant get to (very easily)...
Thank for this, do you lose any suction by using the flexile hose? (probably not with a 3HP motor). Also where is your piping for the tools? should it come off the Y piece?
DennisCA":302k5so4 said:shed9":302k5so4 said:You could fit a cyclone and remove the top bag from the equation all together.
Or he could eject the debris outside into a bin and skip the cyclone. Just make a shed like extension that houses the bin so the dust doesn't go flying all over.
ScottGoddard":3kisghj3 said:thanks, thats a hell of a set up! Are those a set of fliters at the end of the run? What is the piece before the filters?
shed9":iivtq4wo said:DennisCA":iivtq4wo said:shed9":iivtq4wo said:You could fit a cyclone and remove the top bag from the equation all together.
But the air still needs flow via some form of exhaust and a cyclone deals with the bulk of the debris limiting this element of the output.
DennisCA":wqhka4t1 said:The air will have no problems exiting a roughly built enclosure in all directions, all it needs is to roughly guude the air and stop the big pieces from going too far. It will be a bit messy in there so this limits where this solution can work due to neighbors and such. But the plus side is no cyclone, a cyclone robs about half your blowers performance, and a material handling blower is already only half as effective as a caged, non-material handling one.
