woof
Hello all,
Having a nightmare with the simplest of things - trying to put a roundover edge on small pieces of wood (12cm x 7.5cm; 15cmx 15cm) and it keeps catching. Router is in a table, I have turned down the router speed as the cutter diameter is 38mm, bearing guided, but wonder if I really should have it closer up to full speed - the problem is the wood keeps catching when I get to the final pass ruining my hard efforts!
In addition, to do stopped dados in these sizes, do I have to make a dummy jig? I really must find a routing course to go on, since its the one bit of equipment that gives me the willies.
Thanks in advance
Mark
Thanks in advance
Mark
