sploo
Somewhat extinguished member
I'm a new/novice turner (so far I've done a few spindles as learning pieces, and one bowl). My long term goal is medium/large segmented bowls.
I have a bowl and a spindle gouge, a roughing gouge and a parting tool, but no scrapers or skews.
I've seen a number of turners using replaceable tip tools, such as the Easy Wood (http://www.easywoodtools.com/easy-turning-tools/) and Sorby Turnmaster (http://www.robert-sorby.co.uk/sov-rstmd ... master-set).
I quite like the idea - in that it would give me a dovetail cutter for chuck mounting. The square edged scraper looks ideal for getting a spindle down to a specific diameter (a more "engineering" presentation of the tool, as opposed to the "artist" skill of running a gouge along the length). Finally, the round tool looks ideal for shaping the inside of bowls (especially where I want to create something with straight internal walls and a tight radius between the walls and bottom).
Am I on the right lines with these tools, and how do they compare? The size of the Sorby holder seems to require the toolrest being quite a distance from the workpiece, but then you get a versatile set (where the Easy Wood needs a different holder for each cutter).
Would it also be worth me holding off until I've got more experience using the "traditional" tools?
