Hi,
I've been commissioned by my daughter to make file suspension insert for a deep drawer in her traditional-style pedestal desk (it's a modern-ish reproduction, but decent quality I think). She wanted something which could be dropped-in and removed as required, rather than simply permanently attaching suspension runners to the drawer - a sort of rigid cage with runners at each side on the top. The width of the drawer is such that the tolerances are pretty fine. I've designed it allowing 1mm clearance either side of the insert.
Like an silly person, I only measured the internal width at the rear of the drawer, assuming that the sides would be parallel (the insert cage must, of course, be parallel). When as a check I came to dry-fit the cut pieces of the cage frame, I discovered that the drawer is tapered, being 2mm narrower at the back than at the front (drawer is about 31 cm from back to front). Fortunately, I had by chance taken my measurements from the narrow end, so no problem with the fit - just bit sloppier at the front than I expected.
I can see the point of tapering a drawer in this way (help avoid jamming?). My question is this: is this sort of taper normal on drawers of traditional construction? Or did I just get one that was made on a Friday ?
Regards
Chris
Regards
Chris
