Wood Monkey
Hi All
As a first time poster (but long time reader) on this site I'd like to firstly acknowledge the quality and depth of the information that's available within these pages, well done to all involved and Sorry for the long post.
I need some help. I'm on the verge of buying a new table saw and, based largely on the reviews and comments from this site, I think I’ll be twanging the plastic at a TS2500Ci (but I’m still open to late persuasion). Previously I’ve been limited by space, but despite this I have managed to work reasonably well with my EB PK200 with extension and sliding table (bound for Ebay). I’ve found the EB to be pretty reasonable and accurate once set-up, but can be knocked out of square, so I’m looking forward to the arrival of a big slab of cast iron.
My new workshop is built at the end of my garden and measures 18x14ft with almost 10ft to the top of the ridge and 7ft to the eves and a monster thick concrete floor. One end has 7ft wide double doors which open onto a utility area if I need more space. Best of all it’s dedicated, so there’s none of the usual space gobbling items that generally render my garage useless. So it’s almost perfect…… Errrr, no.
My problem is that the workshop is 75 feet away from my house and the only access from my driveway is down the side of the house or through the house and out the back door. The side way is just wide enough for a standard wheelbarrow and the route through the house is limited by standard door widths, door sills and so on. So my question is, has anyone had a TS2500Ci delivered to a restricted access site? I’m not so much worried about the weight coz I’m happy to build a trolley that can go down the side of the house and across the lawn, but are there any ‘breakdown’ options for delivery and would you consider it advisable to ‘build up’ the saw myself. My local dealer says the delivery drivers are only obliged to drop the saw on my drive (I’m guessing this is direct from NMA).
Some additional questions. I think I have plenty of space, so is the 2m sliding carriage worth it or stick to 1.4m?
Micro adjuster on the fence, is it worth it?
After looking over a TS2500Ci at a dealer, I was a little surprised at the amount of play that was evident with the standard mitre gauge in the table slot. Have any users had issues with this?
On the same dealers table, there seemed to be some rocking evident on the sliding carriage, is this likely to be down to a badly set-up showroom saw?
Cheers, Jon
Cheers, Jon
