Dart-head router cutter ?
Cordy
1 Dec 2014
Wigan
Looking for a source for half inch diameter router cutter with tip like a dart
To fit in my plunge router to get good central position on the wood; then swap to standard cutter to do the biz
I've seen them on USA you-tubes but can't find any here
Any info much appreciated
Have an idea:
I bought two lengths of silver steel bar stock recently, 1/4" and 1/2" diameter (from that well-known auction site). The main intention is to be able to check the router is squarely in the router table and the tall fence is properly parallel. If you did similar, it's a work of moments for some nice chap with a lathe to turn a point on the end of a piece, and cut it off to length.
Would that work? I think I paid about four quid for the 1/4" and six quid for the 1/2" piece, both being around a foot long (far too much really). BTW, they're also handy to reset the drill press, because the table on that tilts.
Cheers Erik
Saw the add on *bay; sadly no friends with a lathe
Oakmitre thanks for Wealdon link; Ordered one of those
Got the idea from George at one minute
you don't need a lathe to do that, you need a drill and a belt sander.
cut a short piece, chuck it up in the drill, spin it against the belt at an angle to get a nice point. matter of seconds for 1/4" few minutes for 1/2". it will be close enough to centre for what your after.
All you need to set the table of a drill press it a length of coat hanger wire with a 45deg bend in, clamp in the chuck and spin it by hand adjust the table so it just touches the table all the way round and your table is level.
Ordered the Wealdon Dart as per Oakmitre at 10- 30 Thursday night
Arrived Saturday morning; good product, job sorted :lol:
Wealden are very helpful and their service is excellent. Not everything they sell is actually on the website, so it is worth giving them a call. They sold me a 3mm arris router cutter, it is so much better than a roundover and blends the roundover into the top surface without any step.
That sounds really useful - the number of times I've tried rounding over with slightly warped stock...
Isn't that what a block plane is for Erik? :wink:
It was 6mm HDPE sheet I was routing with a guide template underneath. It just makes it easier when rounding over from both sides.
