The Original Poster, back in January, made a request for advice in making a jig to help deep cutting 10" oak on his (Record bs 305s) bandsaw, as he ended up with a pair of wedges!
Fast forward to August the 10th, and a new post offering the advice to use a "dumpling" between the bed and workpiece,
to vary the angle of cut, as you would do with a handsaw.
Which I fail to see how this dumpling or even a piece of brass is the latest, will help the bandsaw cut in a straight line.
And I still don't.
On reading the link below, on the Record bs350s bandsaw, The makers sell 3/4" blades for it and claim cast iron bed and trunnion for strength.
So, on reading the BS350s link, the blade size is not the issue, nor is the blade tension capability.
So surely we arrive at setting up the bandsaw, in this instance, 3/4" Tuffsaw blade, tracking, guides and thrust bearing set up.
Enter Mr Snodgrass for most of us, He certainly knows Bandsaws.
Maybe Record will make and sell banana shaped tables and saving those dodgy dumplings!
Regards Rodders
http://www.recordpower.co.uk/product/pr ... cySQXFViko
