woodpig":1v342c5r said:Do any of you know at what position the carriers need to be in for the jaws to form a perfect circle? I have the Axminster Clubman.
A perfect match for the SK80 chuck these popular C jaws feature three separate gripping methods. An external dovetail which opens into a 50mm recess, a 40mm internal diameter stepped shoulder for a firm grip on the outside of a spigot. A screw chuck can be purchased separately for use with these jaws. Recommended range: 35-55mm internal, 50-70mm external. Although designed to fit the 80mm chucks these jaws will also fit the 100mm versions.
CHJ":310vlfle said:For 100mm Axminster chuck See here
Grahamshed":3hlooju8 said:Or do you mean how far in do they need to be for a full circle hold ? in which case I think it is about 1/8 of an inch from fully closed.
Thanks. I didn't realise those dimensions represented circularity. I'll have to set my C jaws at 27mm then remove them and carefully check the diameter between the carriers. 27mm is not a very helpful size, I wish they'd made it 25mm then I could have used some 25mm bar or turned down some 1"!CHJ":3pb0tr5n said:For 100mm Axminster chuck See here
woodpig":32d0xrnz said:Thanks. I didn't realise those dimensions represented circularity. I'll have to set my C jaws at 27mm then remove them and carefully check the diameter between the carriers. 27mm is not a very helpful size, I wish they'd made it 25mm then I could have used some 25mm bar or turned down some 1"!
CHJ":svc0d59o said:What on earth are you trying to achieve?
woodpig":2k9pgqb9 said:I'm thinking of making some of my own jaws and want to get the recess for the carriers as close as possible to the correct size. I didn't ideally want to judge it solely by eye.
CHJ":2k9pgqb9 said:What on earth are you trying to achieve?
Any particular reason for the rudeness Chas? :roll:
woodpig":11xul8hr said:Do any of you know at what position the carriers need to be in for the jaws to form a perfect circle? I have the Axminster Clubman.
woodpig":6m9ugnuh said:Oh dear, you seem to have got yourself into a bit of a tizzy Chas.
If you recall this thread started with a simple question:
woodpig":6m9ugnuh said:Do any of you know at what position the carriers need to be in for the jaws to form a perfect circle? I have the Axminster Clubman.
I didn't give a reason for asking it as it didn't seem relevant but as you've wound yourself up making lots of wrong assumptions I feel I should put your mind at rest.
I happened to mention to someone that Axminster tools only make button jaws (I bet the penny's dropped at this point but I'll continue) in either 150mm, 250mm or 400mm sizes which isn't so useful to my 350mm capacity lathe. The cost is also quite high at £164.95 for the larger ones even if they did fit.
Knowing that I make a lot of my own tooling It was suggested I make my own and it was even mentioned that some suitable allow plate may be made available to me free of charge.
I'm not actually sure of the practicality of doing this but a simple test on some small scrap may prove the point.
Hence my original question.
If I intend to do this I want to make the groove to locate the jaws as accurately as possible. I hope this makes things clear.
Apology, such as it is accepted by the way.
In that case I am amazed that you can not quickly measure the true PCD of the location/safety keys and have to ask on the forum for this information, it is a matter of 20-30 seconds at most to find and measure.woodpig":39otufqj said:.......Knowing that I make a lot of my own tooling It was suggested I make my own and it was even mentioned that some suitable allow plate may be made available to me free of charge.
woodpig":2udg6yor said:I'm thinking of making some of my own jaws and want to get the recess for the carriers as close as possible to the correct size. I didn't ideally want to judge it solely by eye.
CHJ":2udg6yor said:What on earth are you trying to achieve?
Stiggy":9lq5kzkg said:Your original question wasn't too clear which is why I deleted my first post.
woodpig":6assus94 said:CHJ":6assus94 said:What on earth are you trying to achieve?
